RE: Mick Reeves Hunter
Started planing the bits and bobs that will go in the fuz.
Batts will be right in the nose.
RX, switch, servos for all pneumatics, air gauge, air fill will all be on the tray at the bottom of the pic.
Airtanks just behind with airtrap on top (off set so that I can still get at the wing bolts).
Main tank just behind. (just ordered new one from Als Hobbies)
All turbine stuff (ECU, pump, solenoids etc) will be in the engine bay just in front of the turbine.
