RCU Forums - View Single Post - GSP Katana 72"...DETAILED BUILD and 3D FLIGHT REPORT
Old 08-15-2003 | 12:00 PM
Dangerous Dan's Avatar
Dangerous Dan
Default GSP Katana 72"...DETAILED BUILD and 3D FLIGHT REPORT
Was it a miracle Y?, I am thinking about saving up for digital servos at least for the elevator halves. I can borrow/buy a programmer, reverse one of them electronically, match the centers, match the endpoints, then put them on a standard heavy duty Y. Otherwise I will use seperate channels and always! check the p-mix switch before flying. I have 5 planes on this radio, what I was in a fun fly and switching between planes when I forgot the switch and lost my plane. This plane is getting expensive, but on the brigt side If I save up and go with 5 HS-5928 (1-rud, 2 ale, 2 elv) I can re-use them in a 33%-40% plane in the future.
You can get your eclipse updated to PCM cheap
http://www.hitecrcd.com
click on Eclipse QPCM update
$99 +$5 s/h
update firmware and hardware to PCM, with added functiona and get a 9 channel PCM receiver
$25 + $5 s/h
update transmitter no receiver
