RE: HPI Vorza Flux HP
Doing some bearing and diff oil maintenance tonight. I got some new bearings in and I am planning on changing my diffs oils as well. Any recommendations for Front/Center/Rear diff oils? I am going to run up to hobby town after work and grab a couple different weights and play with them. I have been doing a lot of research online and found a lot of pro drivers will use lower weights. I have seen a lot of 5000/5000/3000 weights for front/center/rear. Is this not a good idea for someone not as experienced as them? Will that make my car a little too loose or aggressive? I have an HPI Vorza. It's on the heavy side so I was thinking like a 10k center and maybe a 5k or 7k front and rear.
Any advice is greatly appreciated. Thanks!
