Some day, you can rip it off along with the skin it is bonded to..
Honestly, you have been on RCU since October, 2010 and you havn't put a kit or an arf together... then gotten CA on your fingers? Well, that's part of the RC hazing!!! You HAVE to pry your fingers apart at least once to get past this step in the hazing. Next comes the paddles... oops... sorry, I broke the oath of silence...
I get that on my fingers all the time. After it sets up, I just peel most of it off. I would be carefull trying chemicals to get it off, though. Some chemicals that will work on CA are also somewhat toxic.
I had a tube that I didn't notice, had fallen over and started dripping on my coffee table. Well, the next morning, I had a glob of solid CA on my table that I needed a chisel to get off. So, wipe off as much as you can then, after a while, as I said, you can probably peel off what's left.
CGr.
