RE: Dean Connectors
You need a soldering iron that can put out some heat and maintain temperature....also tin the wire well. I tin the wire and the connector then give the end of the wire a little squeeze with a pair of pliers to make a flat on it. Then its a simple matter of holding the two together and applying heat while feeding in a bit more solder. It sounds so easy doesn't it?
