RCU Forums - View Single Post - Air Power 5-Function Valve vs. Fly Eagle 5-Function Valve?
Old 05-10-2011 | 06:28 PM
Bill Hatcher
Default RE: Air Power 5-Function Valve vs. Fly Eagle 5-Function Valve?
The difference in the FEJ and The AP is that you can program the AP. Unless FEJ has upgraded there unit you have to go with the setting from the factory.
I install the AP valves in most of my builds and they work great.
They are easy to set up once you do it a few times but the instructions are not the best.
Hope this helps
