RE: Carb Question
If you have a spray bar that protrudes into the venturi, the area must be taken into account. That is to say a venturi with radial fuel feed of a given diameter has greater throat area than the same diameter with a spray bar in it. Venturi design is simple and a fuel passage in the side of the venturi itself is perfectly acceptable, and is not a detriment, unless the overall design is poor.
