RCU Forums - View Single Post - Air Power 5-Function Valve vs. Fly Eagle 5-Function Valve?
Old 05-11-2011 | 12:39 PM
EagleJC
Default RE: Air Power 5-Function Valve vs. Fly Eagle 5-Function Valve?
FEJ Valve has couple different versions.
One is very simple and anotehr one is new version with display on, gear failsafe, door timing set upt function.
Also, there are different nipples with 3mm or 4 mm airflow for small models or big models. If you got large viper, you might change to 4mm nipples.
Valve is not a copy, do not make it wrong.
James
