RCU Forums - View Single Post - CA glue
Thread: CA glue
Old 05-11-2011 | 01:17 PM
tony0707
Default RE: CA glue
HI
WHEN you get a cut-,apply CA to close and seal the cut ,the CA will fall off as the cut heals
CA is used in surgerys like the liver where stitches cannot be used
there is a VERY SHORT TIME FRAME but if you act fast enough you can whipe the liquid CA off with a paper towel before it has a chance to dry ,if some solidifys on you skin ,it seems to fall off in a short amount of time soap and water help
building for 26 years ,use CA for the majority of my building to make things move along QUICK
good to use TIGHTBOND on sheeting you know will require sanding- ,CA gets a bit difficult to sand out on seams or wood joints -when you want a very smooth balsa surface
years ago we only had slower drying glues-AMBROIDS,DUCO CEMENT ,SIGMENT- ,ELMERS ETC. ( showing my age here ) CA has improve my modeling world FOR SURE-but important to use it with CARE
ENJOY BEST REGARDS TONY
