RE: How to hover?
Elevator drops... Some call it "Parachute", See in the video I posted, when the plane is dropping kind of straight down with a little forward momentum, but flat? That is an elevator drop. Then once you get close to the ground, you increase nose attitude into a harrier. Once in a harrier, you can "Drive" the plane around the field where you want it to go just feet above the ground. Mastering this helps refine your movements on the sticks.
