ORIGINAL: iamzoli
i'm doing now my turbine support for k80e . what do you thing is it correct ? i calculated with excel =DEGREES(ATAN(7/80))= 5,000644598 angle
by ''down trust'' is meant that the front turbine is pointed up and the thrust down . correct?
i want to know before i giving it to cnc.
thanks
also do i need some right to left angle for horizontal alignment?
Yes the front (starter) up and the back down, but the actual direction of the thrust is up not down
