RCU Forums - View Single Post - CMP EP Katana SR
Old 05-12-2011 | 08:46 AM
stick man
Default RE: CMP EP Katana SR
You're right, I guess the Flaperons are a seperate deal from the elev.
I played around some more last nite and found that I cant get the Aile to work unless the Flaperons are 'on'. Otherwise the DX7 thinks there is only one servo for both Ailerons, and the manual indicates this as well. I will experiment some more tonite to see what I can figure out. At the very least I'm learning more about my Tx.
And I'm starting to understand mixing but as a new pilot I'm just not sure what to mix and how much. I guess it will reveal itself when i get more time with this plane.<br type="_moz" />
