RE: engine idle problem
At what RPM is the engine idling with the ignitor on it? Have you tried to increase the idle RPM a little to see if it will idle if it's allowed to run a little faster? It truly sounds like you're trying to get it to idle too low. Another thing to try is to change to a heavier prop. Sometimes the added flywheel effect is all that's needed. Hope this helps.
