RCU Forums - View Single Post - Telemaster 40
Old 05-12-2011 | 05:56 PM
EscapeFlyer's Avatar
EscapeFlyer
Default RE: Telemaster 40
ORIGINAL: DUCO
Interesting that you should bring that very detail up, I do plan to do just as you have suggested, this is the only thing I have seen that I thought could use a bit of strengthening. I will use a trick I learned long ago to keep from popping a rudder off, the rudder sets into the slot you build into the stab, then this whole affair is attached to the back end of the fus.
I will add bamboo dowel pins into the rudder that will be attached to a block under the stab/fus. This should add additional strength and stability to the tail. I also thought about adding wire bracing, seen this on another Tele, but have not made up my mind. I also was wondering since I was up-gunning w/a bigger engine, which was here today, but mailman took back to PO f/me to sign, I was @ work of course! Adding wing braces? I understand if you give too much throttle, you induce wing flutter????? Any help would be great appreciated.
I realize this is a bit of nostolgia, so please forgive me...
When I was 15/16 years old, I lived in Williston, ND. My brother-in-law would bring me to the local fly field so I could watch him fly. Their was a gentleman that had a Telemaster 40 set up with a .60 size 2 stroke. The airplane was rigged to release gliders into the air at altitude.
I have always wanted to do that. Now, if I can find someone interrested enough to fly gliders at my new club, I will be doing this most definitely!
My Telemaster 40 had a Magnum .61 on it and built completely stock. I never had an issue until my friend flew it into a few power lines...
The wing fluttered gracefully forever before it hit the ground. The fuse... that was a different story, however.
Brian
