RE: Greatplanes Cherokee 40 ARF Assembly Thread
Thank's a lot....
Now to my frustration....
GreatPlanes, after messing with the wheel collar screws, now messes with the small screws that bolt the nylon control horns in place.
There length is not enough for coming out of the other side of the ailerons, so, you cannot bolt the backplate of the horn.
This is also very annoying because the backplate ads to the strength of the whole assembly....
I have used some drops of thin CA+, but i am not really sure if it will hold up.
