RCU Forums - View Single Post - IS ASP 52A 2 STROKE GOOD?
Old 05-13-2011 | 05:08 AM
Dale Campbell
Default RE: IS ASP 52A 2 STROKE GOOD?
I have purchased 3 new of the ASP52A 2 stroke engines. I put them in 3 differant aircraft. I ran all 3 to break them in and have the same problem with all 3. All 3 are mounted inverted and have tried everything I can think of and can not get them to idle down. They run strong at full throttle but as you throttle back to half throttle or below they quite. I have made all landings dead stick. I am using #8 OS glow plugs and changed them many times. I did notice when sitting with fuel in tank they all will drip fuel from carb untill tank is empty. Is the idle adjuster my problem or are they not good engines. Dale
