RCU Forums - View Single Post - NX7.6 engine stalling consistently
Old 05-13-2011 | 07:09 PM
Dolo
Default NX7.6 engine stalling consistently
I'm really, really stumped on this. I've run 4 tanks of fuel through the engine now, so I'm getting a little tired of break-in. I want to start moving the car around, at least slowy to begin with, but Ifind that every time Istart to apply throttle, the engine stalls.
I find it consistently stalls almost as soon as Istart to open the throttle up - even when I open the throttle very, very slowy. I've found this with the HSNanywhere from 2.5 to 4.5 turns out (I swear that needle has NOaffect on tuning this engine, by the way - Ican turn it two full turns before it starts to either flood and stall, or the idle starts getting very erratic. Note that as Iopen the HSNup, Ifind I can open the throttle a bit more without it stalling, but it still stalls within a few seconds. Ihave left the LSNat approx. 1 turn out the whole time (factory setting).
I'm running approx. 25% nitro fuel, and the original R3 glow-plug that came with the car. I'm going to try a fresh LRPR4 plug for the next run, and I'm going seal the engine (It seems well sealed - the carby is solidly attached, will not move. I've had the backplate off already, and when Iput it back on Itightened the screws up well.
Any suggestions? Anyone else have this problem? Did you find a solution (don't suggest replacing the engine - Iwill, but I'd like to at least run the current engine into the ground before Ido that)
