RE: Prop question
Longer prop with a smaller pitch= more torque for better vertical pull, shorter take off runs, slower landings and will slow down the top speed of your plane. A smaller prop with a higher pitch= a faster top speed. If you look in a tower talk at the APC prop selection they now lable them for use. Sport, pattern and 3-D. If you look at the pitches you will get a pretty good idea of the pitch use.
