RCU Forums - View Single Post - What's gone wrong with carburetor/engine?
Old 05-15-2011 | 04:56 PM
captinjohn
Default RE: What's gone wrong with carburetor/engine?
ORIGINAL: BadAzzMaxx
Get some carb cleaner, Crank engine and spray the carb cleaner on all the joints but do not let it go into the carb. If the RPM changes when you spray a spot you have a air leak there.
Milton
You can use WD40 also to spray joints....it will change RPM at a leak. Capt,n
