RE: Platt Zero Build Thread
Did some more fuse work today, but I wanted to share the rudder control horn problem I had with using the robart retract tailwheel...
First of all, I decided to do pull-pull for the rudder instead of the plan's control horn. Then I realized the in either case, the horn would interfere with the retract (when up)... so I redid a new control horn with a big "U" in the middle... I hope the pictures make it clear...
It's all installed now, and the linkage is solid.
<br type="_moz" />
