RE: Extreme Flight Vanquish 2m Build Thread
Matt,
There are no provisions for a pipe. The entire bottom of the fuse is foam sheeted, starting behind the chin cowl. I'm sure if someone wanted to modify it, it could be done. There is a chin cowl so you could get to the motor area easily if needed.
I will have to weigh my ESC unless someone else has a Castle HV 80 ICE weight handy,
Arch
