ORIGINAL: MetallicaJunkie
ORIGINAL: captinjohn
ORIGINAL: BadAzzMaxx
Get some carb cleaner, Crank engine and spray the carb cleaner on all the joints but do not let it go into the carb. If the RPM changes when you spray a spot you have a air leak there.
Milton
You can use WD40 also to spray joints....it will change RPM at a leak. Capt,n
is this done at WOT or just at idle.... this trick is new to me
Do it as slow as the engine will run.
Milton
