RE: E Flight HABU 32- P-20SE Build thread+Videos*
Chris
CA or silicon sealer. The tailpipe to cool ring has them glued to the cool ring only, with the tailpipe a slide fit to the required distance for cooling 5-6mm. On the two Habu I have done, I glued the cool tube/ fuselage spacers to the fuselage with CA and used two small drops to hold the cool tube in position. I can remove the tailplane halves without taking the tail pipe out, a long 2.5mm ball driver goes between the two tubes
Dave
