RE: Mate two Channels
Hi,
If you go into the SYSTEM | CH ASSIGN menu, you can assign a function to any of the 10 channels. For example, Rudder is assigned to channel 4. You could also assign Rudder to channel 5 (or another) to have two rudder channels. You can then use the SURFACE menu to make adjustments to each Rudder channel independently. In the SURFACE menu, per the example above, RU would be displayed under both CH4 and CH5.
I hope this helps.
Regards,
Todd
Team Airtronics
