RCU Forums - View Single Post - Propeller balance
Old 05-17-2011 | 09:54 AM
Lnewqban's Avatar
Lnewqban
Default RE: Propeller balance
The easy-fast-safe solution is replace the prop.
If in need of saving that prop, I would check it with a strong light and a magnifier, looking for crack lines.
If you find none, smooth the edges with a file or sandpaper and re-balance taking material away from the other blade.
