RCU Forums - View Single Post - Bizarre plane behavior
Old 05-17-2011 | 11:20 AM
JohnBuckner's Avatar
JohnBuckner
Default RE: Bizarre plane behavior
ORIGINAL: vh2
Because the Flite Streaks are much more sensitive than most models, George suggests moving the balance point up to the front of the leading edge and adjusting for minimum control movement as you get used to the Flite Streak's maneuverability''
Mr. Aldrich is absolutely correct And that is exactly as I would have advised however it is no longer a controlline airplane. RC airplanes and controlline airplane have completely different requirements. Agine if it were mine I would balance at 20% MAC aft of the leading edge.
I could not say for certain whether or not this airplane was designed with the unequal span or not, However that makes the problem even more difficult with your limited ailerons. If the airplane came with the ailerons then they were never intended as ailerons but flaps that were mechanically mixed with the elevator and the purpose was to operate opposed to the elevator and tighten up inside as well as outside loops.
Are you an experianced RC pilot? You see while RC to controlline conversions are relatively simple, controlline to RC are not and loaded with many problems. So if you where hoping to use this as some sort of RC trainer then that was a bad choice.
John
