RE: Official Radio Shack Golden Arrow Thread
hi karim
the GA is a rip off of the tamiya hornet
so i would think all the parts off the hornet will fit the GA
as for the electrics the GA was made by nikko for radio shack (tandy in the uk)
so any 1/10th scale electrics from a nikko car will work fine
if you want to replace the old radio gear with new gear
you will have to cut away at the insides to make room for the steering servo
you will need a normal transmitter with a N/R switch as the GA servo is backwards
also a esc and a reciever
hope that helps
