RE: 50cc throttle problem
The Walbro-carb feeds itself with fuel, this is done via pulses from the crankcase. You will need a hose with a filter on to feed the carb (a clunk in the tank with filter on), and a hose to return the fuel to the tank. And also some sort of ventilation in the tank. No need to create pressure to make it feed from the tank.
