RCU Forums - View Single Post - HELP??
Thread: HELP??
Old 05-17-2011 | 06:48 PM
FOOPED
My Feedback: (8)
Default RE: HELP??
Your 30A ESC is delivered to the electric motor and the 11.1 volt is your battery supply. Yes you can use the 11.1 volt 4000 MA battery as long as you can ballance your CG. Thats like a water bottle, the more MA the more water you have in it. Longer flight time. You will have to have a increase in you charge rate or longer charging time. Now as far as knowing all the high tech to your questions I will have to pass and maybe someone will help you out in that field.
