RCU Forums - View Single Post - engine position
Old 05-18-2011 | 03:31 AM
Steve Percifield's Avatar
Steve Percifield
My Feedback: (14)
Default RE: engine position
That's probably done to get the exhaust centered on the bottom of the fuselage. As long as the carb is close to the centerline of the tank it will run fine. The engine doesn't care how it's mounted. If the tank centerline is much above the needle valve , it will siphon fuel and you might have some tuning problems.
