RCU Forums - View Single Post - Need help adjusting thottle servo
Old 05-18-2011 | 03:10 PM
Goran619
Default RE: Need help adjusting thottle servo
This is what I could find on Futabas site
<u><font size="3">
Setting ATV values on your system: </p></font><font size="3" face="Times New Roman,Times New Roman"><font size="3" face="Times New Roman,Times New Roman"><p align="left">1. Enter the programming mode, and get to the </p><p align="left">2. To set the RIGHT aileron motion, move the aileron stick all the way to the right and hold it. The letters "</p><p align="left">3. To set the LEFT aileron motion, move the aileron stick all the way to the left and hold it. The letters "</p><p align="left">4. To set travel volumes for other channels, press the </p>
5. You may set each channel separately, anywhere in between 10% and 120%, and if you wish to rapidly return to the default 100% setting, press both the (+) and (–) keys simultaneously. </p></font></font><font size="2" face="Arial,Arial"><font size="2" face="Arial,Arial">ATV </font></font><font size="3" face="Times New Roman,Times New Roman"><font size="3" face="Times New Roman,Times New Roman">screen with the up or down arrow keys. The channel indicator is below numeral 1 for ailerons, the percent symbol will be flashing, and you’ll notice that you can change the </font></font><font size="2" face="Arial,Arial"><font size="2" face="Arial,Arial">L/D </font></font><font size="3" face="Times New Roman,Times New Roman"><font size="3" face="Times New Roman,Times New Roman">indicator to </font></font><font size="2" face="Arial,Arial"><font size="2" face="Arial,Arial">R/U </font></font><font size="3" face="Times New Roman,Times New Roman"><font size="3" face="Times New Roman,Times New Roman">(or vice versa) by moving the aileron (right) stick. In Steps 2 &amp; 3 you will see how you set the travel directions independently for each stick (or knob or gear switch) motion. </font></font><font size="2" face="Arial,Arial"><font size="2" face="Arial,Arial">R/U</font></font><font size="3" face="Times New Roman,Times New Roman"><font size="3" face="Times New Roman,Times New Roman">" should appear next to the flashing percent sign, meaning you are setting either Right or Up travel (with ailerons it’s right or left only, but the display is set up to use the same indicators for elevator and throttle, thus the dual meanings for the letters). Now if your servo is stalled or binding, you’ll hear a buzzing sound. Hit the minus </font></font><font size="2" face="Arial,Arial"><font size="2" face="Arial,Arial">DATA INPUT </font></font><font size="3" face="Times New Roman,Times New Roman"><font size="3" face="Times New Roman,Times New Roman">key until the buzzing stops. If the servo is not buzzing, leave the setting at 100%. Later, after flying the model, you may wish to increase or decrease this number depending on how rapidly the model rolls to the right (you may also use dual rates to reduce your model’s responses). </font></font><font size="2" face="Arial,Arial"><font size="2" face="Arial,Arial">L/D</font></font><font size="3" face="Times New Roman,Times New Roman"><font size="3" face="Times New Roman,Times New Roman">" should appear next to the flashing percent sign. Again listen and hit the minus </font></font><font size="2" face="Arial,Arial"><font size="2" face="Arial,Arial">DATA INPUT </font></font><font size="3" face="Times New Roman,Times New Roman"><font size="3" face="Times New Roman,Times New Roman">key until the buzzing stops. If the servo is not buzzing, leave the setting at 100%. You may wish to increase or decrease this number depending on how rapidly the model rolls to the left (or use dual rates as mentioned before). </font></font><font size="2" face="Arial,Arial"><font size="2" face="Arial,Arial">CURSOR </font></font><font size="3" face="Times New Roman,Times New Roman"><font size="3" face="Times New Roman,Times New Roman">key to select the channel you wish to change. The little triangle moves and indicates the active channel. Repeat steps 1-3 with each channel in sequence, taking care to set the travel for both directions. </font></font></u>
