RE: Need help adjusting thottle servo
So when the throttle stick is down the carb is closed? and at half stick its fully open? If that is the case then just adjust the D/R until you get full travel. This should give the carb full travel with full travel of the throttle stick. If that doesn't work then I'm out of suggestions.
Jordan
