ORIGINAL: mr_matt
I will speak to Wilcox in the next day or so and I will follow up, PM me your SN or name and I can ask for you.
I agree, 2.5 volts does not sound right. The max voltage would be much higher to truely drive the RPM that high. Unless it is a sensor problem of some kind and it did not really hit that high rPM
Matt, I was there when the U-Flash flamed out. Bri has fun it full throttle on the ground (short periods) with no problems... on the first flight, after rotation and going into a right turn, the engine quit....
