RE: Need help adjusting thottle servo
Another thing that may help is move the control horn outward on the servo horn it will give more throw then. When you put the control rod back in the control horn on the carb did you use the same exact hole? also when you put it back in you may not have gotten the engine back exactly and that may be why its off but its hard to say.
Jordan
