RE: Need help adjusting thottle servo
SOme new info, the control rod is on the outside hole on both control horns. The manual says to connect the rod when the throttle and trim are both down/closed. I did that but the horn on the carb can be moved 360 degrees so I'm not positive where its supposed to be when the throttle is closed. When connected that way it still travels too far when fully opened, the ATV fixes this but like I said earlier from what I can see it doesnt just control how far it goes in either direction it also makes the movement between half stick and full stick open very little preventing any speed changes between those two stick positions. Is this normal? If so I dont think I like that method becuase I dont want to be full throttle when I'm at half stick.
