RE: Need help adjusting thottle servo
Bob,
The first thing you need to do is make sure that the throttle control horn is at 90 degrees to the control rod when the throttle barrel is at mid travel. The same applies to the servo end as well, but since you say things were fine before let's assume for now that the servo end is correct. As stated by others, there are some very good explanations already in the forum with some very good drawings to illustrate.
