Did you find any inconsistancies in mounting the wing?? I mounted mine last night and found that once I had the wing centered, the side of the flap for the left side was about 3/16" closer to the fuse than the other one. Seems the flaring on the body was out a little. You could even notice the panel lines were off from each other. Just wondering if you ran into the same stuff.
Will you be posting a video of the maiden??
PS, Cockpit looks great!
