ORIGINAL: Merlin Man
Hi,
Thank you for your quick reply. I had thought of this too ( the noseweheel and the angling of the blocks ) but failed to do either !!
I will try again.
Cheers MM.
You could retro fit. I drilled holes of varying depths into the hardwood bearers, approx 3/8th" deep at the rear, reducing down to almost 1/16th or so at the front. Then I "hacked" away at the remaining wood with a dremel until the two surfaces were roughly flat. I then bedded the retract unit onto a layer of epoxy and microballons spread onto the bearers, to ensure the frame did not distort as the screws were tightened.
