RE: Started my first kit build
Thanks everyone for the positive comments. I am truly enjoying the build so far, working through the challenges and learning the process. I have made some more progress and have installed the leading edge, top spar, dihedral braces, and sheeting between the top and bottom spars in between each rib.
I am now on hold until I can get to the store and get some epoxy, the stuff I had went bad and harden within a couple minutes of mixing it. I need to epoxy the leading edge to the bottom sheeting and also the dihedral braces.
I think I am using too much thin CA as you can probably see from the pictures. It comes out really fast even when I’m trying to just add a couple drops. Any suggestions?
