RCU Forums - View Single Post - Mounting a 26cc Ryobi upside down?
Old 05-22-2011 | 09:12 AM
Kostas1's Avatar
Kostas1
Default RE: Mounting a 26cc Ryobi upside down?
ORIGINAL: DougT
Bob,
I've been running the Gen II. for a while now and am fairly happy with it. CH ignition makes it idle awesome and the sound is too cool. BUT, I did mount it inverted for exactly the same reasons as you and lost about 1000 rpm and the idle was not reliable. It also wanted to puke out some of the oil from the case breather tube. I understand that the Gen III have the breather on the valve cover. Is that correct? It may make inverted better or worse. I'll take a head-on pic of the Ryobi with a height and width measurement and post back here.
Check out this. I want to start building it this summer. The main holdup is milling the crank for it.
DougT did you ever finish this opposed twin ?
I'm really interested...
