Alasdair, good idea with the elevon mixer configuration. Most modern transmitters we use have that function. But what do you then do with the elevator control..??..If I remeber correctly from earlier testing just hooking the elevator servo with an Y-cable to one of the elevon servos will only make it move "halfways"...?!
.....please advise...Thanks..
Throttle control was OK so we will let it be for now.
BTW, do you ever fly your N.S. from water..??...this ship is not built water proof as far as we can see but that can be fixed with a larger pot of glue....
Plan to move all servos forward to eliminate/minimise ballast in the nose while fixing the broken nose wheel.....Cheers/Harald
