RE: CMP 120 Zero ARF Build thread
Bean thanks for the insight
i had mine set at 135 prior to all the recent changes and additions full cockpit and full pilot sliding canopy split flaps and scale exhaust and dle 30 engine not to mention strengthening the gear mounts and glassing the wing etc which all will add weight just hope its where its needed most but i do expect mine much like Misha to tip the scale close to 16 and half if not 17 lbs so i will heed your advise and set it at 130 mm as a starting point and work from there
thanks again for the flight report!
