RE: Anyone use a Zeiss Jena 2.5cc diesel?
Thanks for your info....Greet stuff.
I have managed to make a pin! the engine now is in OK condition and should be good for starting.
Now just to concertrate on the fuel formula....ether is the main problem now!.
I did find a can of Motor Start helper for diesel and other engines. But no cemical content on the label!!!
It does have that strange smell and it did expand the rubber parts of the fuel tank that I used for Glowplug engine. and the silicon tube went soft also, so I think that there is some ether in the can, also evaporising quickly.... Then I think I need some improver also cause when I tried to start the thing with no valve PIN it sometimes just made ONE ignition turn and then nothing.... resulting in flooded engine...Before I try to make a new formular I think I better try to get original ether , and try with no amyl nitrate....I recone it should start...
Thanks Guys Earl , Gmadeson, etc.
