RCU Forums - View Single Post - anyone use this servo?
Old 05-24-2011 | 08:27 AM
opjose's Avatar
opjose
Default RE: anyone use this servo?
ORIGINAL: Mr Cox
Where do you draw the line between micro and mini, to me it is a little fuzzy....
I haven't seen any clear definitions (mini, micro and nano doesn't really mean anything here), the HS-65HB is 11g and pulls 1.9 kgcm. If that is not enough then there is also the HS-81, guess that is more in the ''mini'' range.
It's dependant upon weight, size, torque and mounting style.
Most mini's have TWO screws for instance because some of the medium and higher torque servos produce MORE torque than medium standard size servos.
I've often used MINI servos as drop in replacements for standard servos on .50 and smaller planes, to shave off a bit of weight.
