RCU Forums - View Single Post - VSX 1/72 RC Tanks
Old 05-24-2011 | 10:12 AM
shenlonco's Avatar
shenlonco
Default RE: VSX 1/72 RC Tanks
well towers order came in today and they sent me the sherman and tiger ... not the T34 o well like the sherman better anyhow.. lucky my other order for a sherman was canceled due to not in stock error.
anyhow first impressions they look great
Driving not to good they just are not smooth maybe after a while the tracks will wear in... I feel VS should of used plastic snap type tracks then they would drive real nice...
Maybe a VS hop up?? VS YOU LISTENING?
On further notice they kind of waddle not run smooth and especially at slower speeds due to the fact that VS don't know how to make a perfectly round and true front drive sproket!! It's because the gear drives drive sproket wheels are so out of round why they don't work smoothly... if they where true these would run great!
another problem with my tiger I i noticed my tiger could hit the sherman from like almost 20ft and my sherman hit the tiger from only like 9 feet ... I found my tigers IR sensor was sunken down inside the turret to much so i used a pin and pryed it up higher now both tanks work the same... this was a problem on one of my FOV 1/24 tanks also the sensor was hot glued way down and i would not get hits on it also so i took it apart and reglued it in the normal hight position and it worked on the FOV tank also so this is how i knew to check for this on the new VS tanks...
Still have to test on the MAD battle field.!!
