RCU Forums - View Single Post - anyone use this servo?
Old 05-24-2011 | 12:50 PM
opjose's Avatar
opjose
Default RE: anyone use this servo?
ORIGINAL: Mr Cox
I still haven't seen any definition on what is mini and micro, HK seems to think that mini is when the weight is between 11-20g so that would include the HS-65HB.
Nope the HS-65HB is too small to fit a MINI servo requirement.
ORIGINAL: Mr Cox
I have tried other servos from HK and don't like their quality, and frankly I do not understand why some people are so defensive about stuff from HK. It is like the emperors new clothes or something...
If you've tried "other servos" you should post which specific servos.
HK sells many different servos, some MUCH better than others.
They run the gamut in quality and price.
Frankly I do not understand why some people immediately assume that JR, Hitec or Futaba are the only "good" servos out there, and ridicule all others or act to cast aspersions on things they have not tried.
I've used well over 350 servos and the highest consistent failure rates I've had is from Hitec.
Going by that methinks the Hitec Emperor is naked. I've never taken to knocking Hitec's though...
