RE: Y.S 170DZ CDI spinner-prop issue
The sand paper works the best, you don't need to glue it to the backplate.
I use a Craftsman 1/2" socket wrench & hold the very top end of the wrench when tightening. If you use a double jam nut, you can tighten the first one fairly tight but not the second one. I never have one come loose except when running too lean & back fired.
Adrian
