RCU Forums - View Single Post - CMP 120 Zero ARF Build thread
Old 05-25-2011 | 03:30 AM
  #849
misha034's Avatar
misha034
Default RE: CMP 120 Zero ARF Build thread
After colision with FW 190 (my son and his soccer ball)
I had to repeint part of the wing size of 5x5mm.
Since I started painting, I thought that I could paint a few small things.
This white plastic is the upper part for securing 4 screws for aileron horn.
now it is looking much better
As for the Thunderbolt, I have printed label with the details of cocpit and cabin areas,
and instrument panel in front of the pilot.
After I trim plane, and if it can take some more weight, I will make sliding canopy and
details in cocpit with parts that Mike send to me.
The rest of the cabin I painted over with black paint and then did a little sending to
get a visual impression of several uears of usage
I've already started I move the paint, brushes, solvents and catalysts when I remembered that I could paint the screws
used for attaching canopy, as well as those for the rear wheel cowl.
On top side screws will be dark green color and on the bottom a light gray green..
