RE: Y.S 170DZ CDI spinner-prop issue
Tanks for the suggestions, I am going to use the sandpaper until I replace the trust washer and by the way I've already replaced it once for the same reason. A fellow modeler at my field drilled his trust washer and spiner backplate and inserted a rolled pin into it, this is yet another idea I might do if the problem persists !
