RE: Robart spring-down gear problem
I also found out that no matter which retacts you use you need to make sure that the mounting rails are perfectly flat. The units cannot be twisted when you tighten the mounting screws down. I had to place a small washer under mine to make them perfectly flat.
Ralph White
